Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Lany P' and U' charts are being added in JMP 17. We've considered adding tests for over and under dispersion, but there does not seem to be consensus in peer-reviewed publications on an appropriate method. Do you know of any cited references?
Thanks Steve, we've found that as well. However, no references are cited that we can find. Still looking for a peer-reviewed publications if you come across any.
