  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Kubelka-Munk, S.Golay, reflectance to transmittance, ...
Hi,
after the implementation of the Functional Data Explorer it would be very helpful to extend the transformation possibilities in order to handle spectroscopic (e.g. NIR/ MIR-data) inside this nice and handy platform. To use this kind of data I use "UnscramblerR" on a regular base to convert reflectance data to transmission data, change wafelength to wavenumber, do Kubelka-Munk and/or S. Golay transformations, calculate derivatives, smoothen spectra curves and so on. But as it is quite work intens to import the data into Excel, go to Unscrambler do the calcuations - sometimes more kinds than realy necessary (which I detect afterwards using JMPPRO), back to Excel and than finally to JMPPRO to dig inside the data, it would be a big releave to  do all this things just inside JMPPRO.
Kind Regards
E. Gross
1 Comment
Sarah-Sylvestre
Level V
Hi @egon_gross, thank you for your suggestion! We have captured your request and will take it under consideration.
