%3CLINGO-SUB%20id%3D%22lingo-sub-907424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMantener%20las%20propiedades%20de%20visibilidad%20al%20clonar%20tablas%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-907424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%20%20%20%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%3C%2FP%3E%20%0A%20%20%20%3CP%3ETengo%20muchas%20funciones%20que%20toman%20tablas%20de%20datos%20como%20entrada%2C%20luego%20realizan%20c%C3%A1lculos%20a%20partir%20de%20ellas%20y%20devuelven%20una%20nueva%20tabla.%3C%2FP%3E%20%0A%20%20%20%3CP%3EPara%20mantener%20mis%20funciones%20puras%2C%20generalmente%20comienzo%20clonando%20la%20tabla.%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%3C%2FP%3E%20%0A%20%20%20%3CP%3EEl%20mensaje%20%22%26lt%3B%26lt%3B%20Clonar%22%20debe%20tener%20opciones%20para%20especificar%20la%20configuraci%C3%B3n%20de%20visibilidad%20para%20la%20ventana%20clonada.%3C%2FP%3E%20%0A%20%20%20%3CP%3EAlgo%20como%20Visibiliy(%22Mantener%22%7C%22Visible%22%7C%22Invisible%22%7C%22Privado%22)%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3ESi%20hay%20otras%20configuraciones%20para%20las%20tablas%20de%20datos%2C%20tambi%C3%A9n%20ser%C3%ADa%20bueno%20tener%20opciones%20para%20ellas.%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%3C%2FP%3E%20%0A%20%20%20%3CP%3EJMP%20parece%20ejecutarse%20mucho%20m%C3%A1s%20r%C3%A1pido%20cuando%20no%20se%20muestran%20las%20tablas%2C%20lo%20que%20puede%20acelerar%20enormemente%20los%20scripts.%3C%2FP%3E%20%0A%20%20%20%3CP%3EDesde%20el%20punto%20de%20vista%20del%20usuario%2C%20tambi%C3%A9n%20es%20agradable%20no%20ver%20un%20mill%C3%B3n%20de%20ventanas%20parpadeando%20al%20ejecutar%20scripts.%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CBR%20%2F%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-907424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EAutomatizaci%C3%B3n%20y%20scripting%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E
Keeping visibility properties when Cloning tables
I have a lot of functions that take a data tables as input, then do calculations from it and returns a new table.
To keep my functions pure, i usually start by cloning the table.
The "<< Clone" message should have options to specify the visibility settings for the cloned window.
Something like Visibiliy("Keep"|"Visible"|"Invisible"|"Private")
If there are other settings for datatables it would also be nice to have options for those.
Why is this idea important?
JMP seem to run a lot faster when tables are not shown, can massively speed up scripts
From a user pov it also nice to not see a million windows flash when running scripts.
