Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Fit model allows the user to set up and launch an analysis but not close the launch window. This is useful when iterating through many versions of a model. Add this check box (but leave it unchecked by default) to every platform.
We have many platforms that allows this in JMP, but we are not planning to add this as a general design feature. Also, in my most JMP platforms now, a red triangle option exists to "Relaunch Analysis", which will bring up the previous launch dialog with the settings that were specified for that platform.
