  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Join several table at once
The idea is to be able to join several tables at once. This is possible for concatenation, it would be great to be able to do it for join.
5 Comments
julian
Community Manager
Status changed to: New
Hi @Florent_M,
Join is really set up for just two tables, so this is something best done using Tables > Query Builder. Open all your tables, and then launch Query Builder, then select your primary table, and then add as many secondary tables as you like. JMP will try to detect the keys relating the tables, but you can also configuring the keys yourself. You can then build a query to select the columns and/or rows you would like in your final table. Check out the JMP Help for additional details.
Julian
Hi, thank you for your suggestion! We have captured your request and will take it under consideration.
Status changed to: Not Planned For Now
@Florent_M - We appreciate you submitting your wish, but unfortunately we do not plan to implement your request. As Julian stated, Query Builder is what you should use to join several tables at once.  Let us know if you have any questions!
Olaf
Level I
Hello Sarah,
I have a similar problem: many rather narrow but long tables I want to join, Though there is no "master table". All they have in common is a "timestamp" column.
And I could not figure out how to do this in query builder as I would need an outer join to really get each instance of the timestamp into the final table.
Best Olaf
hogi
Level XIII
