  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Join, Concat and Update
Every day we have new data that need to add/update to the existing data table  I need a simple operation that will be able to concatenate new row(s) and/or new column(s) to the existing table and also update the existing table if the new table show a change in the data value by matching columns criteria.
12 Comments
hogi
Level XIII
#DiscoverySummit2025
dt = Current Data Table();
dtnew = dt << Run Script( "Source" );
dt << Select All Rows << Delete Rows;
dt << Concatenate( dtnew, Append to first table );
Close( dtnew, NoSave );
this short script is a very universal solution for the problem
- till JMP overwrites the source script.
jthi
This can be done with Join platform, but it will always generate new table which can be annoying and user has to know to use full outer join with update main table... option. I think JMP should either implement new table platform or possibly update the Update platform with option of adding new rows. Effective concatenation without duplicates using scripting by matching data in two columns in differ... . Like usually, I have written my own functions to do this, but I think JMP implemented one would be much faster.
If this was a new platform, I would be fine (or possibly even prefer) if this wouldn't even add new columns and would just insert new rows and update existing values. This is quite common operation with databases, upsert (update + insert).
