Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
The save function is a little confusing when the jsl is saved to the data table: in the edit window, you can save it, but it does not save the edit to the data table. You’d have to save the table again, to make sure the associated jsl is saved.
