%3CLINGO-SUB%20id%3D%22lingo-sub-389398%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ESalvataggio%20JSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-389398%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ELa%20funzione%20di%20salvataggio%20%C3%A8%20un%20po'%20confusa%20quando%20il%20jsl%20viene%20salvato%20nella%20tabella%20dati%3A%20nella%20finestra%20di%20modifica%2C%20puoi%20salvarlo%2C%20ma%20non%20salva%20la%20modifica%20nella%20tabella%20dati.%20Dovresti%20salvare%20di%20nuovo%20la%20tabella%2C%20per%20assicurarti%20che%20il%20jsl%20associato%20venga%20salvato.%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-389398%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JSL save
The save function is a little confusing when the jsl is saved to the data table: in the edit window, you can save it, but it does not save the edit to the data table. You’d have to save the table again, to make sure the associated jsl is saved.
