%3CLINGO-SUB%20id%3D%22lingo-sub-558164%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Sugerencia%20autom%C3%A1tica%20de%20JSL%3A%20mejorar%20el%20tiempo%20de%20espera%20-%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-558164%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F26800%22%20target%3D%22_blank%22%3E%40hogi%3C%2FA%3E%20-%20%C2%A1Gracias%20por%20su%20sugerencia!%20Hemos%20capturado%20su%20solicitud%20y%20la%20tomaremos%20en%20consideraci%C3%B3n.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555607%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJSL%20auto%20sugiere%3A%20mejorar%20el%20tiempo%20de%20espera%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555607%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESugerencia%20autom%C3%A1tica%20de%20JSL%20a%20trav%C3%A9s%20de%3C%2FP%3E%0A%3CPRE%20class%3D%22language-jsl%22%3E%3CCODE%3Eobject%20%26lt%3B%26lt%3B%20xy%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%2B%3CSTRONG%3E%20CTRL%20%2B%20espacio%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20es%20genial.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPero%20la%20lista%20de%20sugerencias%20autom%C3%A1ticas%20tarda%20mucho%20en%20generarse%20si%20el%20usuario%20presiona%3CSTRONG%3E%20CTRL%20%2B%20espacio%3C%2FSTRONG%3E%20y%20(*)%3C%2FP%3E%0A%3CP%3E-%20JMP%20a%C3%BAn%20no%20conoce%20el%20objeto%3C%2FP%3E%0A%3CP%3E-%20no%20se%20dieron%20las%20primeras%20letras%20(xy...)%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EAlgunas%20ideas%20de%20c%C3%B3mo%20se%20podr%C3%ADa%20cambiar%20el%20comportamiento%20de%20JSL%20autocompletar%3A%3C%2FP%3E%0A%3CP%3E-%20hacer%20que%20la%20generaci%C3%B3n%20de%20la%20lista%20sea%20m%C3%A1s%20r%C3%A1pida%20%5Besp.%20para%20el%20caso%20%C3%BAnico%20%22mostrar%20todos%20los%20comandos%22%20(*)%5D%3CBR%20%2F%3E%20-%20permitir%20que%20el%20usuario%20abandone%20la%20generaci%C3%B3n%20de%20la%20lista%20haciendo%20clic%20en%20alg%C3%BAn%20lugar%20con%20el%20mouse%20o%20presionando%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20Esc%3C%2FSTRONG%3E%20.%3CBR%20%2F%3E%20-%20en%20el%20caso%20de%20(*)%2C%20generar%20una%20lista%20vac%C3%ADa%2C%20-%20sin%20tiempo%20de%20espera.%3C%2FP%3E%0A%3CP%3E-%20en%20el%20caso%20de%20(*)%20en%20lugar%20de%20generar%20una%20lista%2C%20llene%20la%20ventana%20flotante%20con%20un%20texto%20que%20diga%20que%201)%20el%20objeto%20a%C3%BAn%20no%20se%20defini%C3%B3%20y%20que%202)%20el%20usuario%20debe%20ingresar%20al%20menos%20una%20letra%20del%20comando%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-555607%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3Esecuencias%20de%20comandos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterfaz%20de%20usuario%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JSL auto suggest: improve waiting time
☐ cool new feature
☐ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
JSL auto suggestion via
object << xy
CTRL + space is great.
But it takes very long for the auto suggestion list to be generated if the user presses CTRL + space and  (*)
- JMP doesn't know the object yet
- no first letters (xy...) were given
Some ideas how the behavior of JSL auto complete could be changed:
- make the generation of the list faster [esp. for the unique case "show all commands" (*)]
- allow the user to agort the generation of the list by click somewhere with the mouse or pressing esc.
- in the case of  (*), generate an empty, list - without waiting time.
- in the case of (*) instead of generating a list, fill the Hover Window with a text that says that 1) the object was not defined yet and that 2) the user should enter at least one letter of the command
5 Comments
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
JMP 17: amazing speed now
hogi
Level XIII
can be changed to "Delivered" - thanks a lot!
SamGardner
Level VII
Status changed to: Delivered
