  • JMP 19 is here! See the new features at jmp.com/new.
  • Due to global connectivity issues impacting AWS Services, users may experience unexpected errors while attempting to authorize JMP. Please try again later or contact support@jmp.com to be notified once all issues are resolved.
JMP 19 pop-up banner
I'm working with JMP 18 now and once I create a control chart, I have on top of each control chart a JMP 19 pop-up banner
I would like to permanently deactivate this pop-up banner
Why is this idea important?
There is a way to hide it but this needs to be done for each control chart. This is a pain.
6 Comments
hogi
Level XIII
In the pop-up note there is a hint / command
mia_stephens
Hi @ConvergentTree1 , thank you for your request. The Legacy Control charts will be retired in JMP 19, hence the red banner in JMP 18.  However, most of the legacy functionality is available in the control charts under Quality and Process > Control Charts (including launch dialogs).  Please let us know if there is any legacy control chart functionality that is missing from the newer control charts.
ConvergentTree1
Level I
Hi, I'm sorry but this does not help me. I know that there is a way to hide it but this needs to be done for each control chart. This is a pain. I would like to permanently deactivate this pop-up banner. I don't care about jmp19 at the moment. Thanks
mia_stephens
I understand. There is a JSL command in JMP 18 that removes the banner: Send the command, {Visibility( "Collapse" )} to the textbox.
Saving as a Platform Preset might do the trick.
First, use properties to change the visibility of the banner to Collapse (open Properties, and click on the banner, to see banner properties - visibility is under Edit), and repeat for the second banner.
Then, save as a Platform Preset (here, I've saved as No red banner). You can apply this preset any time you launch this control chat platform, and you can share with others.
See https://www.jmp.com/support/help/en/18.0/#page/jmp/platform-presets.shtml# for more info on using Presets.
Please let me know if this works for you.
Thanks!
Status changed to: Delivered
Marking this as Delivered due to @mia_stephens comment, but please let us know if you would like this to be reopened.
mia_stephens
Thanks @Sarah-Sylvestre . Please note that in JMP 19 this behavior will change. There will be a more subtle note that can easily be dismissed in the report, and this note can be turned off via Preferences.
