Item Wrap and Max Items - Default Legend Settings
Would it be possible to add somewhere in settings a way to set the default Item Wrap and Max Items values of Graph Builder to a different number? I often run data with a lot of categories where the Max items is way too short. Not to mention that on a regular screen the Item Wrap almost always ends up wasting a lot of space, instead of doing one long column and allowing the graph to expand. Ultimately a "smart" setting that adapts the layout to the graph and/or window size would probably be ideal, but at least a way to set the default would be a great help.
Thanks!
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
