Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
@vince_faller , I have JMP PRO 14.3 on windows and here is a screen shot that get namespace names() does return the names. Below is a script that demonstates that show namespaces() with log capture is another alternative.
Names default to here(1);
new namespace("_Test");
new namespace("_Test2");
new namespace("_Test3");
_xx= Words(Trim(Log Capture(show namespaces())), "\!N");
show(_xx);
get namespace names();
Namespace("_Test3") << delete namespace;
Namespace("_Test2") << delete namespace;
Namespace("_Test") << delete namespace;
My first thought is for using namespaces in customer code that we don't want them to have access to. I can encrypt it but if there are flags in place the variable names and values show up. From what it seems I can't even make the variables in a namespace hidden.
__x = 5;
show symbols();
new namespace("__Test",
a = 1,
__hidden = 2,
__hidden_function = function({},
print("hidden")
get namespaces();
I'm just trying to protect proprietary code a little better.
My big use case for JMP 14 is that I'm absolutely loving New Custom Function(). But to use that, it requires the use of a namespace.
