  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Half-normal plots
In the output from a DOE, specifically in the Effect Screening section.  I can figure out how to make the software report the normal plot, but what I really want is the half-normal plot which I can choose in the pull-down menu; however, is there a way I can make the program default to this choice
4 Comments
Victor_G
Hello @EWO-PPD,
In order to automatically display the normal plot, you can go in "File", "Preferences", "Platforms", and then look for "Fit Least Squares".
Then, in the right panel, check the option "Normal Plot" in order to display it by default when you run this type of analysis.
You'll have to switch manually to "half-normal plot", but at least the plot will be here by default for every analysis with the platform "Fit Least Squares".
I hope it helps you,
Sarah-Sylvestre
Level V
Hi @EWO-PPD, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
mia_stephens
Status changed to: Not Planned For Now
As @Victor_G suggests, you can turn on the preference for the Normal Plot, which gets you very close. Changing the status to not planned for now, but we will reopen if there is additional interest/discussion.
