We want to hear your ideas for improving JMP software.
  1. Search: Please search for an existing idea first before submitting a new idea.
  2. Submit: Post your new idea using the Suggest an Idea button. Please submit one actionable idea per post rather than a single post with multiple ideas.
  3. Kudo & Comment Kudo ideas you like, and comment to add to an idea.
  4. Subscribe: Follow the status of ideas you like. Refer to status definitions to understand where an idea is in its lifecycle. (You are automatically subscribed to ideas you've submitted or commented on.)
We consider several factors when looking for what ideas to add to JMP. This includes what will have the greatest benefit to our customers based on scope, needs and current resources. Product ideas help us decide what features to work on next. Additionally, we often look to ideas for inspiration on how to add value to developments already in our pipeline or enhancements to new or existing features.
Graphbuilder: use a column numbers or letters as symbols for graph
What inspired this wish list request? I would like to be able to visualize an additional variable
What is the improvement you would like to see? I would like to create a graph where the symbols or points can be substituted with numbers or letters from a column I select.  See example attached generated in Sigmaplot.
Why is this idea important? This allows display of additional variable without having to hover.
1 Comment
XanGregg
If I understand you correctly, I think you're describing the "Set Shape Column" feature already in Graph Builder. It's under the red triangle menu for the Points options. In this screenshot, I've already selected sex as the shape column. This was new in JMP 16. Before that, the "Use for Marker" column attribute could be used for that purpose, but it applies to all your graphs.
