DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
For convenience, assume the JMP table has has columns: X PRED Displayed as curve LOWER \ UPPER / Displayed as band
You may have an extra column Y Raw data displayed as points
Start Graph Builder Drag X to the X-Axis Select PRED, LOWER, UPPER (and Y if desired). You may have to use the CTRL key (windows) or it OSX equivalent. Once selected, drag PRED, LOWER, UPPER (and Y if desired), as a group to the Y axis
In the Graph Bar, Select the Line tool (position 6) and the Area tool (position 8), and optionally the Points tool (position 1) You may have to use the SHFT key (windows) or OSX equivalent.
In the Graph Builder Control Panel area, below the column list, you should see sections for LINE, AREA , and possibly POINTS
In the AREA section Change Area Style to Range *** Most important Change Connection to Curve Click on the triangle after Variables Keep checks for X, LOWER and UPPER
In the LINES section Change Connection to Curve Click on the triangle after Variables Keep checks for X and PRED
In the POINTS section Click on the triangle after Variables Keep checks for X and Y
You can customize the graph Double-click on Axis labels to change the text Double-click on the Legend to: change legend text which legend entries are displayed Right-click on the line, fill or point with in the legend to change colors, line types, marker types, fill patterns
