  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Graph builder: bug when dragging subplots
☐ cool new feature - no, but:
☑ could help many users !!!!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
When the user changes the order of subplot in graph Builder tby dragging the label on the X or Y axis to another position, strange things happen:
https://community.jmp.com/t5/Discussions/Graph-Builder-settings-for-new-FrameBoxes/m-p/561610/highli...
In this example,
- dragging "height" on the Y axis to the top resets the colors (!!)
- dragging"height" on the X axis to the right does NOT reset the colors (? :) )
- just grabbing and releasing "height" on the X axis resets the colors (!!!)
In addition, when adding new subplots it's almost a gamble how the plot will look like:
The color/marker settings are cloned to new subplots,
if variables are added via drag & drop
- on the right of an existing X variable
- on the bottom of an existing Y variable
and the settings are not cloned if the new variables are added
- on the left of an existing X variable
- on the top of an existing Y variable (99% of the use cases !!!)
please fix the issue!
When a user changes the order of of subplots or adds new variables, some actions should take place on a plumbing layer such that on the porcelain layer  everything behaves like expected.
Why is this idea important?
1) When changing the order of subplots, every user expects that just the subplots change their position - nobody would expect that color settings change.
2) When a user adds variables to the x or y axis, the result should be predictable. The result should be the same - regardless of wether you add the new variable on the left, on the right, on top or at the bottom of the existing variables.
(view in My Videos)
gb = dt << Graph Builder(
	Size( 534, 496 ),
	Graph Spacing( 4 ),
	Variables( X( :height ), Y( :weight ), Color( :sex ) ),
	Elements( Points( X, Y, Legend( 9 ) ) )
// change color/marker settings
scalebox = gb << get legend server();
scalebox << Legend Model(
	9,
	Properties( 0, {Line Color( 43 ), Marker( "Down Triangle" )}, Item ID( "F", 1 ) ),
	Properties( 1, {Line Color( 0 ), Marker Size( 10 )}, Item ID( "M", 1 ) )
// add second Y variable
gb << add variable( {:height, Role( "Y" )} );
gb << add variable( {:sex, Role( "X" )} );
Wait( 0 );
New Window( "Modal Dialog example",
	<<Type( "Modal Dialog" ),
	V List Box(
		Text Box(
			"Try to change the order of height and weight on the x and y axis by dragging either weight or height to the other side. Did the color change?"
		Button Box( "OK" )
3 Comments
hogi
Level XIII
While playing around with this issue, I understand now better why Jmp behaves like this.
After running the script in the first post, the Source code of the Graph Builder Report looks like this:
Graph Builder(
	Variables( X( :height ), X( :sex ), Y( :weight ), Y( :height ), Color( :sex ) ),
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 9 ) ) ),
	Elements( Position( 1, 2 ), Points( X, Y, Legend( 10 ) ) ),
	Elements( Position( 2, 1 ), Points( X, Y, Legend( 11 ) ) ),
	Elements( Position( 2, 2 ), Points( X, Y, Legend( 12 ) ) ),
	SendToReport(
		Dispatch( {}, "400", ScaleBox,
			{Legend Model(
				9,
				Properties(
					0,
					Item ID( "F", 1 )
				Properties(
					1,
					Item ID( "M", 1 )
One can see that the first Subplot with Legend #9 has some special Line and Marker setting , the other Subplots (Legend #10-12) don't. So, the settings #9 are automatically "broadcasted" to the other subplots because they share the same Color column -- and therefore the same legend entries.
This is because the setting was applied first and then the new subplots were generated. The same happens if the user changes the setting with just a single set of items in the legend:
Then the new setting is applied to all plots at once - and in the script the changes just appear for the first legend #.
If the user activates legend entries for each subplot he can change the subplots separately.
Let's switch now to another plot (the code below) and find out what happens. Here, every subplot has it's own formatting (no common color column) and when I take one of the subplot groups (one column on the Y axis) and drag it to another location, the other subplots keep their settings and just the moved subplots forget their settings.
This is an acceptable behavior (**) - because the column could also be dragged to a completely different location (later in the video: to the x axis). Then nobody would expects that the formatting could be copied.
At the end of the video, the column is placed back to the original position - and the plot looks different to how it looked before. This is somehow OK -  should be,  because we already accepted such a behavior (**) :)
It is just a bit surprising.
NB: To get the old plot back, one could press CTRL + Z, or while dragging the column, press ESC.
(view in My Videos)
dt = new table();
dt << add rows(1);
c1= dt << new column ("col1",Nominal,set each value (1));
c2= dt << new column ("col2",Nominal,set each value (2));
c3= dt << new column ("col3",Nominal,set each value (3));
c4= dt << new column ("col4",Nominal,set each value (4));
c5= dt << new column ("col5",Nominal,set each value (5));
c6= dt << new column ("col6",Nominal,set each value (6));
Graph Builder(
	Size( 330, 347 ),
	Show Control Panel( 0 ),
	Graph Spacing( 10 ),
	Variables(
		X( :col1 ),
		X( :col2 ),
		X( :col3 ),
		Y( :col6 ),
		Y( :col5 ),
		Y( :col4 )
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 7 ) ) ),
	Elements( Position( 1, 2 ), Points( X, Y, Legend( 1 ) ) ),
	Elements( Position( 1, 3 ), Points( X, Y, Legend( 2 ) ) ),
	Elements( Position( 2, 1 ), Points( X, Y, Legend( 8 ) ) ),
	Elements( Position( 2, 2 ), Points( X, Y, Legend( 3 ) ) ),
	Elements( Position( 2, 3 ), Points( X, Y, Legend( 4 ) ) ),
	Elements( Position( 3, 1 ), Points( X, Y, Legend( 9 ) ) ),
	Elements( Position( 3, 2 ), Points( X, Y, Legend( 5 ) ) ),
	Elements( Position( 3, 3 ), Points( X, Y, Legend( 6 ) ) ),
	SendToReport(
			{Legend Model(
				7,
				Properties(
					0,
					{Line Color( 3 ), Marker( "Backslash" ),
					Marker Size( 30 )},
					Item ID( "col6", 1 )
			), Legend Model(
				1,
				Properties(
					0,
					{Line Color( 38 ), Marker( "Filled Left Triangle" ),
					Marker Size( 30 )},
					Item ID( "col5", 1 )
			), Legend Model(
				2,
				Properties(
					0,
					{Line Color( 36 ), Marker( "Slash" ), Marker Size( 30 )},
					Item ID( "col4", 1 )
			), Legend Model(
				8,
				Properties(
					0,
					{Line Color( 3 ), Marker( "Filled Up Triangle" ),
					Marker Size( 30 )},
			), Legend Model(
				3,
				Properties(
					0,
					{Line Color( 38 ), Marker( "FilledCircle" ),
					Marker Size( 30 )},
			), Legend Model(
				4,
				Properties(
					0,
					{Line Color( 36 ), Marker( "Filled Down Triangle" ),
					Marker Size( 30 )},
			), Legend Model(
				9,
				Properties(
					0,
					{Line Color( 3 ), Marker( "Slash" ), Marker Size( 30 )},
			), Legend Model(
				5,
				Properties(
					0,
					{Line Color( 38 ), Marker( "Filled Right Triangle" ),
					Marker Size( 30 )},
			), Legend Model(
				6,
				Properties(
					0,
					{Line Color( 36 ), Marker( "Backslash" ),
					Marker Size( 30 )},
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "" )} ),
		Dispatch( {}, "X title", TextEditBox, {Set Text( "1" )} ),
		Dispatch( {}, "Y title", TextEditBox,
			{Set Text( "6" ), Rotate Text( "Horizontal" )}
		Dispatch( {}, "Y 1 title", TextEditBox,
			{Set Text( "5" ), Rotate Text( "Horizontal" )}
		Dispatch( {}, "Y 2 title", TextEditBox,
			{Set Text( "4" ), Rotate Text( "Horizontal" )}
		Dispatch( {}, "X 1 title", TextEditBox, {Set Text( "2" )} ),
		Dispatch( {}, "X 2 title", TextEditBox, {Set Text( "3" )} )
hogi
Level XIII
A common application: use the same color settings for all graphs (M=blue, F=pink).
This can be easily achieved via the Column Property: Value Colors.
In Jmp 17-17.2  it is not possible to use Value Colors as Color in Graph Builder for >1 subplot:
Graph Builder: Color not working for multiple Y axes
Once this issue is fixed, using Value Colors will be again the easiest = best solution:)
By the way: The Color, Marker, ... settings via the legend are one of a few settings which actually have a functionality to auto-adjust to the new layout when subplots are moved, added or removed.
hogi
Level XIII
With JMP 18, the Bug with value colors got fixed.
This makes it less harmful that the bug in Graph Builder is still there
-> use value colors as a workaround.
