🙏 Graph Builder: revert changed axis labels
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
Sometimes a user wants to revert a label and cannot do this:
  1. In Jmp there is a severe bug: after a manual change of an axis label,when you add or remove subplots, this label doesn't stick to the respective axis - the label sticks to the "position": Manual axis labels are 'mixed up' when plotting multiple columns
  2. If a user deletes the text label, he has no access anymore to the label - so: no possibility to edit the label.
    This issue will be fixed in Jmp 18 :)
  3. nice feature: If a user deletes the title of an Outlinebox, the title bar gets removed. But there is no possibility restore the title bar.
Please add commands to revert labels:
a) revert a specific axis label
b) revert all labels of the Graph.
Why is this idea important?
The feature will make the life of a Jmp user much better.
8 Comments
hogi
Level XIII
Local( {outlineBoxes,scaleBoxes, XMLs, CharIds, Ids,teb},
Try(
	outlineBoxes = Current Report() << Xpath( "//OutlineBox" );
	For Each( {ob}, outlineBoxes,
		scaleBoxes = ob << Xpath( "//ScaleBox" );
		// there is definietely any easier way than this one to get the Ids ...
		XMLs = Transform Each( {sb}, scaleBoxes, Word( 1, sb << Get XML, "\!n" ) ); // first line
		CharIds = Transform Each( {xmlCode}, XMLs, Regex( xmlCode, "charID=\!"(.*?)\!"", "\1" ) );
		Ids = Transform Each( {xmlCode}, XMLs, Regex( xmlCode, " ID=\!"(.*?)\!"", "\1" ) );
		For Each( {axisLabel, idx}, CharIds,
			If( Not( axisLabel == "" ),
				Try(
					teb = (((((ob << Xpath( "//AxisBox[@charID=" || Ids[idx] || "]//.." ))<<parent)<<prev sib)<<child) << child)[1];
					teb << set text( axisLabel );
hogi
Level XIII
@mia_stephens , can be archived -> users can use the icon on the GraphBuilder Toolbar.
Status changed to: Archived
hogi
Level XIII
hm, the script works ...
... but has some limitations:
- units are not treated correctly
- The script doesn't reset the label; it guesses the correct one and puts it there. A reset is needed for the column switcher to work correctly.
jwiltsie
Level III
This bug is even worse than previously described: The manual axis label remains the same even if you replace the column with a different column in Graph Builder. This gives a completely wrong axis label for the graph!
jwiltsie
Level III
...users can use the icon on the GraphBuilder Toolbar.
@hogi what icon on the Graph Builder Toolbar are you referring to? Could you give a screenshot? Thank you!
hogi
Level XIII
yes, this bug is really dangerous!!! Fortunately, it was fixed in JMP19 . (*)
In addition, Manual axis labels are 'mixed up' when plotting multiple columns was also fixed.
So,
  1. most of the need for this feature is gone now.
  2. (*) gives us a new workaround to reset an axis label:
    replace the column with a different column - and then switch back to the old column
  3. One can use the icon in the Graph Builder Toolbar (with the limitations I mentioned in a previous post).
    It's this one:
    https://community.jmp.com/t5/JMP-Wish-List/Graph-Builder-revert-changed-axis-labels/idc-p/762199/hig...
jwiltsie
Level III
@hogi, thank you very much for the explanation!
