Goal Plot
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
Please make Goal plot calculate correctly for unequal bilateral tolerances. It does not calculate percent correctly. You need to remove the nominal to make the goal plot work.
Also please add more features to goal plot, allow to modify individual data points, give different row labels, and modify the lines. Should give multiple ranges of PpK, allow to put multi-levels.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
