  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Games-Howell Test (Tukey HSD with Welch's Correction for Unequal Variances) in Fit Y by X
This is probably the most frequent limitation of JMP at my organization.  Unequal variances suggest to use Welch's ANOVA, but options are limited for multiple comparisons with unequal variances.  Steel-Dwass doesn't work well with small sample sizes and it's not clear that it is robust to very unequal variances.
Games-Howell test is effectively a Welch's version of Tukey's HSD and works well with small sample sizes.
7 Comments
bpmaruszewski
Level I
Has a solution for this issue been determined? I too am looking for the Games-Howell post hoc test or something comparable for multiple comparisons when unequal variances and small samples sizes are present.
cwillden
Super User (Alumni)
No movement on this yet from what I can tell, but I started creating an add-in for it recently.  Right now, I have it functioning for X and Y inputs, but hope to incorporate a By variable when I get a chance.  You can try it now if it would be helpful for you.  Here's a snippet of the dialog and report.  Feel free to PM me and I will send it to you.  Recall and Help buttons are also non-functional right now.GH Dialog.png
cwillden
Super User (Alumni)
**Update:  I uploaded an add-in version of my application to the File Exchange: Games-Howell Test (Tukey HSD with Welch's correction for Unequal Variances)
Sarah-Sylvestre
Level V
Hi @cwillden , thank you for your suggestion! We have captured your request and will take it under consideration.
Audrey_Shull
Sarah-Sylvestre
Level V
Status changed to: Delivered
DiscreteIbex427
Level I
Hello, how can I apply the Games-Howell test in JMP 17? This concerns a one-way analysis of variance (ANOVA) with nine levels of the independent variable, where the variances are not homogeneous (based on Levene's test).
