I'd like to request that the Fit Life by X platform be enhanced to allow plotting multiple data columns by the same X variable. The Life Distribution platform supports this (as does the Fit Y by X platform).
To add to this request, it would also be helpful to be able to plot multiple parameters by one or more X variables in either the same plot or in different plots (similar to what is available for the Fit Y by X / Oneway platform).
Fit Parametric Survival is for modeling reliability data, not for plotting. I don't think what I've requested is offered. However, I'm happy to discuss this with someone in case I'm unaware of specific or new features.
Currently, Fit Life by X can only plot one column at a time. It has the option of using two columns, but those are treated as intervals within which the failiure occurs. Basically, the request here is to allow multiple, separate plots for different columns or plot multiple columns within the same plot.
Regards
Mehul Shroff
