%3CLINGO-SUB%20id%3D%22lingo-sub-579104%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAjustar%20curva%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-579104%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E1)%20Es%20necesario%20agregar%20m%C3%A1s%20curvas%20al%20men%C3%BA%20Ajustar%20curva%20y%20ofrecer%20la%20misma%20funcionalidad%20a%20las%20curvas%20de%20la%20plataforma%20Ajuste%20no%20lineal%2C%20especialmente%20en%20torno%20a%20factores%20complementarios%20y%20an%C3%A1lisis%20DOE.%20Tal%20vez%20estas%20plataformas%20puedan%20fusionarse.%3C%2FP%3E%0A%3CP%3E2)%20Puedo%20ver%20algunas%20ventajas%20de%20tener%20en%20la%20opci%C3%B3n%20Modelos%20desplegables%20en%20FDE%2C%20las%20opciones%20de%20modelo%20Ajustar%20curvas%20en%20Wavelets.%20Esto%20podr%C3%ADa%20alentar%20a%20las%20personas%20a%20pensar%20m%C3%A1s%20en%20los%20modelos%20te%C3%B3ricos%20reales%20y%20la%20ciencia%20detr%C3%A1s%20de%20ellos%2C%20en%20lugar%20de%20utilizar%20los%20modelos%20sencillos%20de%20caja%20trasera.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-579104%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EModelado%20Estad%C3%ADstico%20Avanzado%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-580531%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Ajustar%20curva%20-%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-580531%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2867%22%20target%3D%22_blank%22%3E%20%40aharding%3C%2FA%3E%20%2C%20%C2%A1Gracias%20por%20su%20sugerencia!%20Hemos%20capturado%20su%20solicitud%20y%20la%20tomaremos%20en%20consideraci%C3%B3n.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-606042%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Ajustar%20curva%20-%20Estado%20cambiado%20a%3A%20Necesita%20informaci%C3%B3n%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-606042%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2867%22%20target%3D%22_blank%22%3E%20%40aharding%3C%2FA%3E%20%2C%20gracias%20por%20estas%20sugerencias.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%C2%BFPuede%20proporcionar%20m%C3%A1s%20informaci%C3%B3n%20sobre%20las%20curvas%20que%20desea%20agregar%20al%20men%C3%BA%20Ajustar%20curva%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-619744%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Ajustar%20curva%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-619744%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2867%22%20target%3D%22_blank%22%3E%20%40aharding%3C%2FA%3E%20%2C%20C%3CSPAN%3E%20%C2%BFPuede%20proporcionar%20m%C3%A1s%20informaci%C3%B3n%20sobre%20las%20curvas%20que%20desea%20agregar%20al%20men%C3%BA%20Ajustar%20curva%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-714601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ajustar%20curva%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-714601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHola%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2867%22%20target%3D%22_blank%22%3E%40aharding%3C%2FA%3E%20%2C%20cambiando%20esto%20a%20No%20planificado%20por%20ahora%2C%20pero%20podemos%20reabrirlo%20si%20se%20proporciona%20informaci%C3%B3n%20adicional%20(y%20m%C3%A1s%20espec%C3%ADfica).%20%C2%A1Gracias!%3C%2FP%3E%3C%2FLINGO-BODY%3E%0A%20%0A%20%0A%20%20%3CLINGO-SUB%20id%3D%22lingo-sub-714602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Fit%20Curve%20-%20Estado%20cambiado%20a%3A%20No%20planificado%20por%20ahora%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-714602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E
Fit Curve
1) There is a need to add more curves to the Fit Curve menu and offer the same functionality to the Non-Linear Fit platform curves, especially around supplementary factors and DOE analysis. Maybe these platforms can be merged.
2) I can see some advantages to having in the drop-down Models option in FDE, the Fit Curves model options under Wavelets. This might encourage people to think more about actual theoretical models and the science behind them, instead of using the easy back-box models.
5 Comments
Hi @aharding, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
Status changed to: Needs Info
Hi @aharding , thank you for these suggestions.
Can you please provide more information regarding the curves you'd like added to the Fit Curve menu?
mia_stephens
Hi @aharding , can you please provide more information regarding the curves you'd like added to the Fit Curve menu?
mia_stephens
Hi @aharding , changing this to Not Planned for Now, but we can re-open if additional (and more specific) information is provided. Thank you!
mia_stephens
Status changed to: Not Planned For Now
