Fieller's Method Improvements
Thank you for adding Fieller's Method (ratio of means test) to Fit Y by X in JMP 19!  There are some usability issues with this first iteration:
  1. Cannot specify which level is in the numerator or denominator of the ratio.  The test does not recognize Value Order for the X values and just automatically selects the larger mean as the denominator by default with no way to change it.  Users have to save the resulting report as a data table and take the reciprocal of all the fields to flip the ratio.
  2. No 1-sided test.  Currently, users have to know to run a 90% confidence test to get the 1-sided 95% limits.
  3. No error handling or warnings for negative (mean) values or unstable confidence interval estimates
    • It doesn't make sense to test the ratio of a positive to negative value (or vice versa), but the platform provides an output all the same.
    • The confidence limits become unstable as the ratio approaches infinity (denominator approaches 0).  This can often be addressed by taking the reciprocal of the ratio to get a more stable estimate close to 0.
    • The mratios package in R has error handling for negative means and warnings for unstable confidence limits.
I'd like to add some functionality to maximize its utility for users:
  1. Specify which level is in the numerator or denominator of the ratio.
  2. Add a 1-sided test.
  3. Add error handling or warnings for negative (mean) values and unstable confidence limit estimates.
Why is this idea important?
Being able to reliably and confidently say whether a product is X Times Better/Faster than another product is a powerful claim for any business to make.
2 Comments
NathanDavis-CLX
Level I
It would be great to have these features so I don't have to use R for this use case.
SarahGilyard
Thanks for testing out the new Fieller's method functionality in JMP 19. I will discuss these concerns/suggestions with the developer for improvement in the next iteration. Thanks!
