%3CLINGO-SUB%20id%3D%22lingo-sub-690910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ER%C3%A9sum%C3%A9%20de%20la%20forme%20d'onde%20composite%20FDE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-690910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EL'analyse%20de%20la%20forme%20d'onde%20est%20effectu%C3%A9e%20sur%20des%20voies%20de%20donn%C3%A9es%20parall%C3%A8les.Pour%20chaque%20ligne%20de%20donn%C3%A9es%20lorsque%20l'option%20Analyse%20DOE%20fonctionnelle%20est%20s%C3%A9lectionn%C3%A9e%2C%20deux%20courbes%20sont%20produites.La%20premi%C3%A8re%20est%20une%20courbe%20moyenne%20et%20la%20seconde%20est%20une%20ligne%20inclin%C3%A9e.C'est%20bien!Je%20pense%20qu'une%20fonctionnalit%C3%A9%20int%C3%A9ressante%20serait%20une%20autre%20option%20r%C3%A9capitulative%20qui%20trace%20ces%20m%C3%AAmes%20courbes%20pour%20chaque%20voie%20de%20donn%C3%A9es%20c%C3%B4te%20%C3%A0%20c%C3%B4te%20(ou%20au-dessus%2Fen%20dessous)%20les%20unes%20des%20autres.J'ai%20trouv%C3%A9%20que%20les%20voies%20de%20donn%C3%A9es%20%22identiques%22%20ne%20sont%20pas%20identiques%20et%20qu'il%20est%20utile%20de%20visualiser%20facilement%20la%20diff%C3%A9rence%20entre%20les%20voies%20de%20donn%C3%A9es%20et%20de%20tenter%20de%20r%C3%A9soudre%20les%20probl%C3%A8mes%20de%20rendement%20des%20tests.Mon%20travail%20consiste%20%C3%A0%20copier%20et%20coller%20les%20trac%C3%A9s%20miniatures%20dans%20un%20document%20s%C3%A9par%C3%A9.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EVoici%20un%20exemple%20d'une%20seule%20voie%20de%20donn%C3%A9es.Je%20voudrais%20afficher%20plusieurs%20trac%C3%A9s%20comme%20celui-ci%20pour%20chaque%20voie%20de%20donn%C3%A9es%20c%C3%B4te%20%C3%A0%20c%C3%B4te.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22brian68_0-1698336641805.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22brian68_0-1698336641805.png%22%20style%3D%22width%3A%20290px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22brian68_0-1698336641805.png%22%20style%3D%22width%3A%20290px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F58020i0E2DF40FDFD95E18%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22brian68_0-1698336641805.png%22%20alt%3D%22brian68_0-1698336641805.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EUtilisation%20de%20JMP%20Pro%2017.2.0%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-690910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EMod%C3%A9lisation%20pr%C3%A9dictive%20et%20apprentissage%20automatique%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
FDE composite waveform summary
Waveform analysis is being performed on parallel data lanes.  For each data lane when the Functional DOE Analysis option is selected two curves are produced.  The first, a mean curve and the second is a sloped line.  This is great!  I believe a nice capability would be another summary option that plots these same curves for each data lane alongside (or above/below) each other.  I have found "identical" data lanes are not identical and easily viewing the data lane to data lane difference is helpful while trying to resolve test yield issues.  My work around is to copy and paste the thumbnail plots into a separate document.
Here's an example of just one data lane.  I would like to view multiple plots like this for each data lane side by side.
Using JMP Pro 17.2.0
