%3CLINGO-SUB%20id%3D%22lingo-sub-459786%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EEstendi%20la%20funzione%20%22Clic%20destro%2FSeleziona%20celle%20corrispondenti%22%20dalle%20celle%20selezionate%20di%20una%20colonna%20alle%20celle%20selezionate%20di%20colonne%20diverse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-459786%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAl%20momento%20puoi%20farlo%20manualmente%20tramite%3A%3C%2FP%3E%3CP%3ESeleziona%20in%20una%20colonna%2Frighe%2Fselezione%20riga%2Fseleziona%20dove%20(Ctrl%20Maiusc%20W)%2Fimposta%20la%20selezione%20corrente%20su%20Limita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-459786%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Extend the feature "Right Click / Select Matching Cells" from selected cells of one column to selected cells of different columns
At the moment you can do that manually via:
Select in one Column / Rows / Row Selection / Select Where (Ctrl Shift W) / Set Current Selection to Restrict
