Graph Builder statistics locations
Hello JMP team,
Can you look at having the axis resize when using the caption box so that the caption text does not overlap the images on the chart?  So basically shrink the Y axis the amount that the text is sized.  Also, can there be an option for all statistic output on whether it be located at the top, bottom, left, right?  An example is the R2 output from line of fit, it would be nice to have the same options as the caption box text on where it lives in the graph.
Thanks for considering these requests.
Steve
