  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Enable easy variable tracking
In the current version of JMP, in order for a user to view a particular variable, the user needs to use the find dialog. The same is required if the user needs to replace a variable across the entire script. It would be much more smoother experience if when a user selects a variable, all the instances of that variable are automatically highlighted in the script and similarly a suggestion is offered where when the user edits the name of a variable, they are prompted with an inquiry if they would like all instances of the variable to be replaced. This is a feature that is prominently offered in Matlab.
Highlighted variable in MATLAB Editor
3 Comments
Hi @uday_guntupalli, thank you for your suggestion! We have captured your request and will take it under consideration.
In JMP 19, you will be able to highlight each instance of a currently selected word in the script editor.
Status changed to: Delivered
