  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Enable easy variable tracking
In the current version of JMP, in order for a user to view a particular variable, the user needs to use the find dialog. The same is required if the user needs to replace a variable across the entire script. It would be much more smoother experience if when a user selects a variable, all the instances of that variable are automatically highlighted in the script and similarly a suggestion is offered where when the user edits the name of a variable, they are prompted with an inquiry if they would like all instances of the variable to be replaced. This is a feature that is prominently offered in Matlab.
Highlighted variable in MATLAB Editor
3 Comments
Sarah-Sylvestre
Level V
Hi @uday_guntupalli, thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
In JMP 19, you will be able to highlight each instance of a currently selected word in the script editor.
Sarah-Sylvestre
Level V
Status changed to: Delivered
