Easy DoE problem statment
Is it possible to add an open text field to the Define tab in Easy DoE, so that the problem you are trying to solve can be stated? Perhaps this also could be included on the top of the report tab? This would make it possible to connect the designs to different projects, teams, purposes or other reasons.
3 Comments
Sarah-Sylvestre
Level V
Hi @Steffen_Bugge, thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
Sarah-Sylvestre
Level V
