Easily Generate FPC Scores in Functional Data Explorer (FDE) for New Data
What inspired this wish list request? I am using FDE to create FPC Scores to use as inputs to into a Generalized Regression model.  I would like to use this model outside of JMP Pro as part of a quality Control Process.  While I can use the GenReg model outside of JMP, I have no way to generate FPC Scores from the time series to use as input.
What is the improvement you would like to see? I would like to be able to to export code that takes the time series as input and exports FPC Scores.  If that is too difficult, at least create a way to generate FPC scores from new data inside of a JMP sheet.  Ideally both solutions.
Why is this idea important? This idea is important because while creating a solution in JMP is great, being able to use the solution in a quality control process is necessary.
1 Comment
anchildress
Level III
I also would like the ability to save the Functional PCA scores from the FDE platform for further analysis and visualization.
