  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Display column notes as Tooltips on column headers
What inspired this wish list request? We're building a tool that loads well-documented data sources to JMP (a data mesh, essentially). We'd like to reveal the documentation about column governance, data types, and meaning to users conveniently. We can add these details to the Notes property, but this isn't highly visible.
What is the improvement you would like to see? When hovering over a column header, if the Notes property is defined, show a tooltip containing the column notes. Practically, this would display in just the same way Event Handler tooltips display, but rather than being defined at the cell level, it's defined at the column header.
Why is this idea important? Well-documented data sources allow other capable data-workers to understand, work with, and gain value from the data sources generated by others. For us, this means that the scientists who deeply understand, say, protein chemistry can create data tables with notes that allow those of us (like me) who don't really know what a "pI" is to use the dataset fluently.
5 Comments
SamGardner
Level VII
@Michael_MXAK thank you for the input.  If you hover your mouse over the modeling type symbol for the column in the Columns Pane, it will display the note as a hover box.  We will take your idea under consideration, however.
SamGardner
Level VII
Status changed to: New
We checked into this further, and currently, we do display notes as tooltips when you hover over the column header in the data table.
SamGardner
Level VII
Status changed to: Delivered
Michael_MXAK
Level IV
Ah, I see what's happening! I tested multiple times but I've always tested on columns I've selected before hovering.
I'll amend my suggestion to a bug report, which is that tooltips don't display (on Windows) on column headers if the column is selected (the column header is blue). I'll send it to [email protected]!
Michael_MXAK
Level IV
Thanks @SamGardner !
