  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
DOE Blocking Factor - Total Blocks
When using the custom DOE platform and adding a blocking variable, the only option is to specify how many runs per block there are. Before a run count is determined, it can be difficult to know how many runs per block there will be for a set number of blocks.
An option to choose the number of total blocks, and have the platform determine the number of runs per block based on the number of runs.
Why is this idea important?
Often, when performing an experiment, the number of blocks is fixed, but the number of runs is flexible. Having the platform do the calculation to determine the number of runs per block can prevent having to iteratively change the number of runs per block to get to the right design.
2 Comments
nathanjdavis
Level I
Happens all the time in manufacturing trials when I have a set number of days available to use.
mia_stephens
Thank you for submitting this suggestion @_john_97
