  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Column options
Hello JMP team,
I'd like to suggest the following for the column options:
  • On the columns list located on the left side of a data table, can you add the options for standardized attribute, column properties, formula, recode, and new formula column when you right click on the column?
  • On the main column titles, can you make it so that by clicking on the column and holing the alt key that it will move that column into view on the column list at the left of the datatable?
  • On the columns list located on the left side of a data table, can you add an option to filter by modeling and data type?
Thanks for considering these options.
Steve
2 Comments
hogi
Level XIII
Sarah-Sylvestre
Level V
