Column options
Hello JMP team,
I'd like to suggest the following for the column options:
  • On the columns list located on the left side of a data table, can you add the options for standardized attribute, column properties, formula, recode, and new formula column when you right click on the column?
  • On the main column titles, can you make it so that by clicking on the column and holing the alt key that it will move that column into view on the column list at the left of the datatable?
  • On the columns list located on the left side of a data table, can you add an option to filter by modeling and data type?
Thanks for considering these options.
Steve
2 Comments
hogi
Level XIII
