  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Column Property: Inclusive/forced Values (💚)
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2024
-> JMP 19 : )
short:
In Jmp it's quite complicated to generate a plot like this!
Inclusive values will fix the issue ...
long:
During the Semiconductor Lunch meeting @ Discovery Summit 2024 Europe, we found out that many of us have a similar problem:
GraphBuilder Plots with missing data.
examples:
- date with missing month, day, year ( A way to show a date with no data in graph builder )
- wafer lists with missing wafer (for 25 wafers in a 5x5 grid generated via Wrap, wafer #20 should always be at the same position, independent of how many wafers < 20 are in the data / missing)
- wafermaps with missing dies
- pass / fail
- bins with pre-defined categories (0 occurences for a specific bin)
Motivation via date:
at first glance, nobody will notice that the data for Tuesday is missing - there is not even a label on the axis.
To make the missing day appear, one can add a dummy row, Day of Week = Tue, all other entries of the row: missing.
... till somebody uses a data filter - then Tue is gone:
The only way to make it work: a dummy row for EVERY (!!!) item in the data filter.
And if the user has a chance to change the column for the data filter: for EVERY item in ANY column the user may pick.
Ouch !!!
Please add a column property for inclusive values *) - values which should always show up on the axis.
For days of week: all days of the week :)
For 25 "wafers" in a lot: all numbers from 1 to 25.
For pass/fail : pass and fail . Such that one day when there is a lot with 0 fails the plot will say: fails = 0. Instead of: not showing any number of fails.
Besides usage for axes, also X/Y Group & Wrap should react on the new setting. The same for Overlay and Color.
*) "inclusive"? what is the best name for the property?
- "default value" sounds like
- additional, auxiliary, supplemental suggest that the value is no actual value of the column
- after some discussion, Copilot suggested "inclusive" values - values which should be included, if missing.
Why is this idea important?
With the new column property INCLUSIVE VALUES,
- missing value information gets visible (!!!)
- the plots can be generated MUCH easier
- the generated plots are "robust" (example with Data Filter!)
16 Comments
hogi
Level XIII
As discussed on #Discoverysummit2025, it should be easy for JMP to automatically fill "forced value" for everyday lists like days_of_week, months,  ...
JMP sorts such entries automatically - very comfortable! As the information is there, it just has to be accessed via the Force Values interface ...
Hi @hogi, thank you for sending your feedback to [email protected]
That is the best place to send feedback on a feature in the EA. I am updating the status of this feature as it will be in JMP 19.
hogi
Level XIII
I am very happy with the new functionality, it helps me a lot.
e.g. let's assume we want to plot Physical Activity - but there is no data for Hawaii.
Just use Forced Values - and Hawaii will show up in the plot - with a missing values.
View more...
dt = Open( "$SAMPLE_DATA/US Demographics.jmp" );
dtStacked = dt << Stack(
	columns(
		:Population, :Eighth Grade Math, :High School Graduates,
		:Gross State Product, :Vegetable Consumption, :Smokers, :Physical Activity,
		:Obese, :College Degrees, :Alcohol Consumption, :Latitude, :Longitude,
		:Household Income, :IQ
dtStacked << Select Where( is missing (:Data) ) << delete rows;
The plot looks quite crowded, so let's split the plot by regions:
There is no row in the data table with State = Hawaii, so JMP doesn't know the region. This is why Hawaii shows up in all 4 regions.
... the same happens for all the other states. I was tempted to suggest an extended version of 'Forced Values', but I couldn't work out how to do it. (for values with existing entries, one could ask JMP to use those, don't invent new states in different regions - but how about Hawaii, which is missing in the data table ?!)
This example shows the limitations of Forced Values for the application "show a placeholder in the plot, even if there is no data".
The only way to produce the correct plot is via dummy rows , right?
hogi
Level XIII
forced values for continuous values - see:
https://community.jmp.com/t5/JMP-Wish-List/Column-Property-Inclusive-forced-Values/idc-p/799363/high...
wow, it made it into the JMP Prioritization Survey 2025!
edit: ah, no - refers to another idea ...
see next post.
hogi
Level XIII
Ouch! Just after submitting the last post, I re-read the entry in the survey
and thought about this wish:
Graph Builder: missing data option for continuous values
which asks for something like this:
Status changed to: Delivered
