Color in between spec limits as column properties
Hello JMP team,
I'd like to suggest the ability to have the space between spec limits set in the column properties be shaded.  This would work much like adding "range" reference lines in the axis options.  So the column property box  for setting up spec limits would contain a checkbox for "shade between spec limits" and a box for choosing the shading color.  Since sometime there is only one spec limit, there could also be another input box where you could enter the end of the spec color band .
Thanks for considering this request.
Steve
