  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Color Palette and Manual Color Accessibility
Currently, when you manually need to change a point or a line color, the color picking tool has a preset grid of shades and colors. These shades and colors do not always match the color palette set as the default. For example it is hard to match a manual color to the Universal color palette colors from this menu. When you try to find more colors you get the slider with TOO many options.
The top line of the manual color selector to contain swatches of the color palette set in your preferences. This way you can still use the normal swatch of colors suggested but would be easier to match colors and stick within your preset/preferred theme.
Why is this idea important?
This idea would primarily make the JMP color system more accessible to those with color blindness. It can be difficult to tell if the shades that are in the manual pick are the same shades as what is already on the graph. JMP has color blindness friendly palettes, however as soon as you need to manually adjust any colors the platform is no longer accessible. For non color blind people this would also streamline the process and make it much easier to tweak small adjustments in data visualization.
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
