  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Color-Coding Tick Label Area by Variable in Graph Builder
As a heavy user of JMP, I often work with multiple variables displayed on the same axis in Graph Builder. For example, when axis titles are like ID 2 / THICKNESS 1 / THICKNESS 2 / TIME / ID, due to multiple variables being stacked or grouped, it becomes visually difficult to interpret which tick label belongs to which variable.
I would like the ability to color both the tick label font and the tick label area (the region between the axis title and the plot) based on the variable. This would greatly improve readability and help users quickly distinguish between variables in complex visualizations.
4 Comments
hogi
Level XIII
as a workaround:
by  placing the axis label to the left (instead of: below the axis) it get very easy to find out which level belongs to which type of entries:
 Hierarchical X labels
hogi
Level XIII
unfortunately, via the Properties menu on the right it's just possible to adjust the color in total, not separately:
hogi
Level XIII
In JMP19, there is now a new option "parallel Y Axis" :
New in Graph Builder for JMP 19
Agree: far from what is needed here (Y instead of X, parallel continuous axes instead of nested nominal axes , ...)
but there is the common idea of color guiding to the right axis.
Sarah-Sylvestre
Level V
Status changed to: Needs Info
Hi @MdSabbirAkhanda, does the workaround posted by @hogi solve this problem for you?
