Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
I know there is an add-in for the "Fit Model" platform, but it's not always the easiest to use. It would be quite easy just to add Cohen's d to the output of "Fit Y by X," and this would be quite useful.
Regarding the matched pairs Cohen's d, strecher1 probably knows this, but the proper SD for computing d here is the pooled SDs of the two variables and not the SD of the difference scores.
