Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
I know there is an add-in for the "Fit Model" platform, but it's not always the easiest to use. It would be quite easy just to add Cohen's d to the output of "Fit Y by X," and this would be quite useful.
Regarding the matched pairs Cohen's d, strecher1 probably knows this, but the proper SD for computing d here is the pooled SDs of the two variables and not the SD of the difference scores.
