Background color for nominal axis labels
If nominal values are used on an axis - esp. if such values are stacked in a hierarchy -  it's hard to trace which data belongs to which entry:
In the Axis settins, please provide an option to define the background of the axis labels by the Value Color of the respective label:
This makes the plot much nicer and easier to understand.
It should be possible to activate and deactivate value colors for each level of the hierarchy:
alternative: all levels get the color from one of the levels, like @Thierry_S suggested in
Why is this idea important?
The ability to change the background of the axis labels is a cool new feature to generate more attractivep lots.
It  can be used to highlight a specific value - like in this comparison of 2 test runs:
By the green background color, the focus is directed to the central value - at the intersection of pass/pass devices.
3 Comments
HaltsMaulwurf
Level II
Nice idea!
I also find the x-axis labeling with the slash as a separator sometimes confusing. It would be nicer if you could arrange the labels on top of each other in the order of the hierarchy.
HaltsMaulwurf
Level II
My last issue has already been solved  (thanks for the hint Hogi):
hierarchical axis labels - optimize the plot - JMP User Community
hogi
Level XIII
It also helps with nested X groups:
