Background color for nominal axis labels
If nominal values are used on an axis - esp. if such values are stacked in a hierarchy -  it's hard to trace which data belongs to which entry:
In the Axis settins, please provide an option to define the background of the axis labels by the Value Color of the respective label:
This makes the plot much nicer and easier to understand.
It should be possible to activate and deactivate value colors for each level of the hierarchy:
alternative: all levels get the color from one of the levels, like @Thierry_S suggested in
Why is this idea important?
The ability to change the background of the axis labels is a cool new feature to generate more attractivep lots.
It  can be used to highlight a specific value - like in this comparison of 2 test runs:
By the green background color, the focus is directed to the central value - at the intersection of pass/pass devices.
2 Comments
HaltsMaulwurf
Level I
Nice idea!
I also find the x-axis labeling with the slash as a separator sometimes confusing. It would be nicer if you could arrange the labels on top of each other in the order of the hierarchy.
HaltsMaulwurf
Level I
My last issue has already been solved  (thanks for the hint Hogi):
hierarchical axis labels - optimize the plot - JMP User Community
