I would like to have a Table Script that automatically runs when the data table is opened. As a suggestion, If a Table Script by the name of "Startup" is saved in a data table, everytime the data table is opened, the "Startup" script is run.
And to bypass the execution of the script, if the CNTL key is pressed and held when opening the table, the script is not run.
Not required....see the On Open table script capability
