  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Augmenting DOE from Model - Moving Factors Forward
When augmenting a Definitive Screening Design, there is a need to manually keep track of which main effects are important, which interactions are important, and which squared effects are important, then manually selecting each of these in the Augment platform. This becomes difficult and potentially error prone as the screening design gets larger. Somewhere, perhaps on the data table of a DSD or within the Fit Definitive Screening Design report, an "Augment" button would be helpful. This button would automatically parse the report, select statistically significant effects, and pre-populate the Augment window. This functionality would also be useful in more than just DSDs, perhaps any Fit Model that could be augmented. Precision is important, and if the user must manually find parts a table of parameter estimates there is a potential to make a mistake. Having this would keep mistakes from happening and help get better results from experimenting.
1 Comment
mia_stephens
Thank you for submitting this suggestion @DerekLontine . We are researching a similar idea.
