Hi,
I use the nominal logistic fit model frequently and I wish it would allow me to right click on a prediction profiler graph and select 'save as animated GIF' which would simply make an animated GIF of the profiler response from the minimum to maximum value. Perhaps allowing the user to select some level of increment speed. I would be open to a script in the short-term but this seems like a logical extension of this platform.
regards,
bac
