Allow passing data objects from JMP to SAS
All,
   I am learning SAS and I am geeked and super excited to leverage the interface that JMP has to SAS.
   As I was getting to set up some testing using JMP, I realised the following:
   Currently JMP allows the passing of a single variable from JMP into SAS as a macro using the SAS Submit function. However, I believe there will be a lot of benefit to allow passing of multiple variables or data objects like associative arrays into SAS.
// Works
ex = 1;
SAS Submit(
			 %put &ex;
			 DeclareMacros(ex),
			 GetSASLog( True )
// Fails
ex = Associative Array( {"red", "blue"}, {1, 2} );
SAS Submit(
			 %put &ex;
			 DeclareMacros(ex),
			 GetSASLog( True )
2 Comments
Jeff_Perkinson
Community Manager
This is an interesting suggestion but SAS doesn't have a macro data structure analgous to an associative array, so there's nothing to pass the associative array to.
You can convert almost any JMP data type to a character string using the Char() function and then use Declare Macros() to get that character string into a macro variable.
char_ex=char(ex);
SAS Submit(
			 %put &char_ex;
			 DeclareMacros(char_ex),
			 GetSASLog( True )
Jeff_Perkinson
Community Manager
Status changed to: Not Planned For Now
As noted above, SAS doesn't have complex data structures analgous to the structures in JSL.
