  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Allow common formatting types on Number Col Edit Box
A number edit box can be easily formatted as a date by using the following
numbox = Number Edit Box( 0 ,<< set format(format("ddMonyyyy")), << set(Today()));
NW1 = New Window( "Example", numbox );
However, in order to achieve a similar result with a number col edit box, the formatting requires the user to pass a number as an argument to the format function. This is not intuitive and the user is left to guess what might or might not work. I would like to request the number col edit box also be provided the functionality to accept commonly known formatting types as a number edit box.
Here is an example
// Using Number Col Edit Box
nR = 7;
NEB1 = Number Col Edit Box("StartDate",Repeat(Today() - 30 * 24 * 60 * 60,nR));
NEB1 << set format(format("ddMonyyyy"));
NEB2 = Number Col Edit Box("StartDate",Repeat(Today(), nR ));
NEB2 << set format(format("ddMonyyyy"));
TB1 = Table Box(NEB1,NEB2);
NW = New Window("test",TB1);
See Format a Number Col Edit Box for discussion.
3 Comments
danschikore
Number Col Box and Number Col Edit Box will take symbolic formats, but they take the arguments in a list rather than in a Format() statement.  Try this example:
nR = 7;
NB1 = Number Col Box("StartDate",Repeat(Today() - 30 * 24 * 60 * 60,nR));
NB1 << set format({"ddMonyyyy", 12});
NEB2 << set format({"ddMonyyyy", 12});
TB1 = Table Box(NB1,NEB2);
These messages should be made consistent with other boxes and the documentation needs to update to reflect the usage options.
Jeff_Perkinson
Community Manager
We are working on improvements here to make the syntax more consistent for the various Format messages. This will be available in JMP 16.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
In JMP 16 the << Set Format() message will take arguments in a variety of forms:
Set Format("Fixed", 8, 3);
Set Format({"Fixed",8,3});
3) Set Format(Format("Fixed",8,3));
//Note that the argument can also be evaluated, so you can do something like:
box1 << Set Format(box2 << Get Format);
