Additional options for cross hair and measurement tool
What inspired this wish list request? I use the cross-hair tool and measurement tools a lot but find myself having to write down a lot of information I gain from them, which is a waste of time.
What is the improvement you would like to see? I would like to see the following:
Cross hair
  • Ability to "Pin" the cross-hair tool image
  • Ability to save out the values of the cross hair to a table
Measurement tool
  • Ability for the cross hairs to calculate a slope value that would show under the dx and dy values
  • Ability to force the measurement tool to stick in an "x / y" mode (like when the axis are different data types) vs the "slope" mode (when data are the same data types).  This will allow you to line up the X and Y values to the data more easily.
  • Ability to "Pin" the measurement tool image
Why is this idea important? The cross-hair and measurement tools are amazing at allowing you to interact with your data but the usefulness is muted by having to resort to hand calculating / documenting the information that you gain.
4 Comments
Craige_Hales
combine with Allow pinning/locking crosshairs and rulers to graphs
digitizing to a data table - yes!
shampton82
Level VII
On other item to add here for the measurement tool, be able to change the amount of decimal points in the "length" portion of the output.  Right now it will only show out to 2 decimals when in measuring on an angle.  When measuring at zero or 90 degrees it defaults to 16 decimal places.
shampton82
Level VII
Two other asks for this wish list item.
  1. When you hold Alt and the magnifier glass goes away, can it keep the data table values?  The magnifier takes up a lot of room so it is nice to be able to remove it but I usually want the data values still
  2. Can the magnifier show the value of the color and size values when they are used?  This would help when using the magnifier on a contour plot and bubble plot.
Thanks for looking at these additional requests!
shampton82
Level VII
Hey @Sarah-Sylvestre !
I just wanted to see if anyone from development has had a chance to review this wish.  It is one that would be really really helpful to me and my team.
If I had to prioritize them it would be:
Cross hair
  • Can the magnifier show the value of the color and size values when they are used?  This would help when using the magnifier on a contour plot and bubble plot
Measurement tool
Thanks for any updates!  (This also goes along with this wish list) Be able to easily convert the cross hair tool lines into an axis reference line - JMP User Community
