  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Tree map "squarify" addtional option
What inspired this wish list request? I use the tree map as a the base graph to report out a dashboard of summary statistics for multiple areas in my plant.  The current squarify option leaves some "boxes" almost useless.
What is the improvement you would like to see? I'd like to see a "forced square" option in the Layout drop down menu that would make the boxes all the same size, which could mean that there are blank boxes if there are not enough categories to fit a even row/column matrix.  Ideally every box would look like chem mill stacked or heat query stacked.  You can see on dry times stacked that there is one long and skinny box that is hard to see.
Why is this idea important? Dashboards are becoming key tools for conveying operational status quickly so charts that are easy to see all the elements are vital.  This is also critical as we move to JMP live as dashboard style graphics are a main reason for the move.
