Adding options to analyze nominal Y's
1. Multiple-comparisons for nominal Y's (as for continuous Y's in Fit Y by X and in Fit Model).
2. Multi-way contingency tables for factorial layout of X's, and a nominal Y.
3. Contingency table: give proper titles to the last column and last row (e.g. "Y sub-total" and "X sub-total").
4. Contingency table: when "Col%" is requested, it should be presented also in the "Y sub-total" column and when "Row%" is requested, it should be presented in the row of "X sub-total".
1 Comment
lyness
Level I
Yes, please have follow-up multiple comparison tests for contingency tables (as is available in ANOVA).
Thank you,
Scott
(Using JMP Pro 16.2)
