AddIn: add options insert_first & insert_last
☐ cool new feature
☐ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
In a jmpcust file which is used to specify the menu structure in AddIns, one can use the settings insert_before and inser_after to specify the position of a command relative to an anchor position.
unfortunately, Some Functions change their internal name with the language .
Therefore the anchor position can just be found for a specify language setting. If the anchor position is not found, the command will not be added to the menu.
Please provide an alternative way to specify the positon if a command in a menu - e.g. insert_first & insert_last
Why is this idea important?
not important - I tell all my colleagues to switch to the English version.
Nevertheless - the new feature
- will allow to specify the position withon a menu
- AND will guarantee that the command is added independent of the language setting of the JMP installation.
1 Comment
Sarah-Sylvestre
Level V
